Idea Options
- Mark as Read
Change mode commands using Google Home assistant
is avaiable a list of Google assistant commands?
I need to change the Mode using Google assistant, for example: "ok Google set Arlo in programmed mode"
Or
"Ok Google set Arlo in deactivate mode"
See more ideas labeled with:
Comments
- 2
- 3
- 2
- 3
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
