Idea Options
- Mark as Read
Rotate image 90 degrees
Status:
Future Consideration
Submitted by
pcom
on
2015-01-10
12:41 PM
I've got my Arlo focused on the walkway leading up to my house which is longer than it is wide. Arlo currently allowd me to rotate the image 180 degrees so I can mount it upside down, A 90 degree rotation would let me turn the camera on its side and have more vertical resolution where I need it.
Comments
- 16
- 17
- 18
- 16
- 17
- 18
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
