Arlo|Smart Home Security|Wireless HD Security Cameras|NETGEAR
Top Contributors
Disable SSID Broadcast
Can the SSID Broadcast be disabled or Hidden from the Base Station?  thanks!
19 Comments
Would also be nice to set the channel.
Another vote for more control to manually select the channel and hide/not broadcast SSID
I assuming #netgear doesn't want to answer the question??
I would like to disable broadcasting as well.
ersantana3,
Currently this is not a feature of the Arlo system. I encourage you to kudo this idea (if you have not already) if you would like to see this implemented in the future. Giving ideas kudos is the best way to support and contribute to ideas on the idea exchange.
Disabling SSID broadcast is an easy fix, & an obvious security issue!
Novice
It'd be nice to edit the SSID as well, since I'd like to opt out of geolocation.
I need to have a capability to change the SSID as hidden one. I don't want to broadcast my SSID that containing "NETGEAR" . It means someone bad will know what type of product we are using as a security device !
So, there should be an option to hide our SSID.
Thanks,
Neka
While I do understand that hidden SSIDs can be seen with special software, I just think its an extra layer of security to not broadcast it.
A casual hacker will look for SSIDs that he can see, then try to hack it.  Not broadcasting the SSID will at least make this type of hacker move on to the ones he can see.  If you're dealing with someone who uses that special software to find hidden SSIDs, he would be a more advanced hacker and there's nothing much you can do to stop him.
I believe the best and easiest way for Netgear to fix this security issue is to only broadcast the SSID when synching with a new camera.  When the user presses the Sync button on the base station, turn on the SSID broadcast so the camera can find it.  Once the sync is complete, turn it back off.
PLEASE Netgear, consider the relatively simple enhancement.  It would put a lot of us at ease!
Fledgling
much needed improvement.  i have these in a rental property and eveyone thinks it is a wifi connection.  Really weak that they do not have a "hide ssid" button.
Onlooker
I would also like the option to turn the SSID Broadcasting off. At an absolute minimum the option to change the DEFAULT names of the network broadcast.
Sure, SSID cloaking is pretty trivial to uncover but leaving your SSID a default looking name also invites attention in that it appears you're using default/lazy security practices. Think: if someone can't go to the effort of changing the wifi name from xfinitywifi12345, the bar may not be very high if you wanted to break into their network.
C'mon, Netgear. This should be baked in from the beginning. I never saw the old Vuezones broadcast so I'm not sure that I believe that it's absolutely necessary. (And just because a lot of people don't ask for it- because they may not know better- doesn't mean it should be brushed off). Kudos to the folks on this page for pointing it out!
