- Community Home Home
- Community Browser:
- English
- Arlo Forum Discussions
- Arlo Idea Exchange
- Allow Customizable Minimum Recording Time with Mot...
- Mark as Read
Allow Customizable Minimum Recording Time with Motion Detection
Currently when accessing Edit Mode → Edit Rule → Recording Settings there are only 2 options: one based on when motion ends and one based on a fixed time. I would really like to see some finer controls added to the Record until Activity Stops option.
The problem I am encountering right now is that the Arlo Pro camera is providing several short videos instead of one long, continuous video. I believe that this is because the system thinks that motion has stopped (perhaps someone walking up to the front door paused for a couple of seconds, for example) and so it stops recording until motion resumes. I think that a simple solution would be to add a user-configurable option for "time to record after motion stops". If this field were set to 10 seconds, then the camera would continue to record for 10 seconds after motion stops. Further motion during this countdown would then refresh the 10 second countdown.
This way, if the value were set sufficiently large a user would be able to get one continuous video instead of several short videos. I assume that such a buffer time already exists in the system's logic in order to counteract this issue on an even smaller scale, so it would be great if that could simply be made user-configurable.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Arlo Baby
78 -
Arlo Video Doorbell
34 -
Arlo Audio Doorbell
33 -
Arlo Security Light
Arlo Pro 3 Floodlight
15 -
Arlo Ultra 2
Arlo Pro 4
Arlo Essential Spotlight
Arlo Essential
Arlo Essential XL
