- Mark as Read
Unlimited live streaming...
I understand that the Arlo Pro 2 cameras can do unlimited recording with cloud storage if you pay extra for the plan. My question is, if I want to live stream continuously to an iPad, it times out after about 30min. I would like to continue to use the multiple Arlo Pro 2 kit for my house so I can have a unit outside observing the driveway and swingset to watch my kids, but at the same time also have one inside monitoring our baby. I understand it isn't the "baby monitor", but as I just described, it can be used for other means both inside and outside, such as in the basement to monitor the kids playing, etc. It makes the most sense to allow for me to monitor all of these things simultaneously since if the baby is napping, it's useful to be inside with the baby but to still be able to monitor the older kids playing outside.
I understand the issue with the Arlo Pro 2 if it is on battery power to have it turn off after a set period of time, however, this unit can also be wired. Perhaps there could be an option to "disable the 30 min timeout" default setting, or the unit could just notice that it is plugged in and automatically turn off the "time out" default. This seems like an incredibly easy fix to just "allow continuous live streaming when plugged in" or something to that effect. Myself and other family members that I have recommended this to may have to move on to another product if this simple option isn't available.
- 2
- 3
- 4
- 2
- 3
- 4
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
