Time Format
Why not use international timing format (24hrs) instead of the US Format (am/pm) only.
Comments
Sadface
So,
2016 i saw a thread about making it so you can choose 24hour clock instead of 12/am/pm.
What is happening? How do I change?
AImeeWalton
It's not even just that it's irritatingly fixed as 12 hour format with no option for 24 hour, it has a leading zero which is usually used to signify 24 hours format.
This problem is compounded when receiving notifications on iOS as the AM/PM wraps onto the next line making it look even MORE like a 24 hour time.
Time format wrapped in notifications.Time format wrapped in notifications.
trulskaare
Novice
Can't believe Arlo still haven't added 24hr time as an option. I thought this was a global company, not just for America. Lol, just noticed it says my content was last auto-saved at 05:25 PM at the bottom here. Do you design your products in inches and feet too?
Donnaiola
Novice
I am sure most European users would much appreciate a military time format. This has been requested on this site before, as long back as in 2016. What is the current status on this issue now? Is it a technology problem (sounds strange, should be a quick fix) or is it just lack of will?
MH84
Novice
Pls fix this
Accel84
Novice
24h format would be very nice. Please
darthvoid
Come on Arlo, please implement that, it's easy.
The AM/PM system is very confusing for most people. Especially around midnight and noon.
thomasjohnsen
Observer
Another weird thing, Arlo app Library uses 24h format. This inconsistency is very annoying!
Here is a screenshot showing the notification, and the Library entry for the same event.
(Pic doesnt seem to work, here's a link:)
https://ibb.co/0rxn4hk
I believe it's tailored for your geography/language (as is the date format in your screen shot).
It'd be nice to allow the time format to be set.
Embedded images won't show until they are manually approved - which can take a little while.
GRoelS
Novice
Please enable the possibility to switch to the international (24hrs) time format!
