Idea Options
- Mark as Read
Tap on Push Notification opens live view of initiating camera
(Note: I'm an Android user - I'm not sure how this works on iOS)
The primary reason that someone would use a push notification is so that they're notified immediately when there's motion.
I'd suggest that the best behavior when clicking on a push notification is that it opens the live view of the camera that initiated the notification.
Additionally, an app-level setting to optionally choose to open the library entry associated with the push would be helpfull. That way, if you view the notification later, you can immediatly link to the recorded event.
Comments
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
