- Mark as Read
Send Push Notifications and/or Emails no more than once every X minutes for specific camera
It would be nice to have an option when setting up Alerts to have a Time selector for each camera and/or Rule. That way you could say:
Send Push Notifications and/or Emails no more than once every 30 (or 60 or 90 or 120) minutes for events on THIS camera.
It could hopefully be set for each camera or for each Rule.
That would seem to be more secure than simply having to turn off alerts entirely because of false/unimportant motion events.
Maybe there could be an option to select an Override for the above alert limitation if more than 'X' of your different camera motion/audio triggers occur within 'Y' minutes of each other. For example, if you have chosen not to be notified more than once every 120 minutes for motion triggers from camera #1 because it covers trafiic on the street, the override would kick in if you decided to be notified immediatley if 3 out of 4 of your cameras trigger within 5 minutes of each other - or perhaps if one internal home camera triggers within 5 minutes of an external camera event.
I would find these more flexible option helpful. If anyone else does as well, please hit the Kudo button.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
