Recording 15 seconds prior to motion event
Since the Arlo Essential doesn't support continuous recording, it would be a great feature to be able to capture the lead-up to a motion event. Currently, the camera might miss a portion of the motion event.
A 5 to 10 second look back would be great.
Comments
JessicaP
Thanks for posting your idea! Our development team routinely reviews posts in the Arlo Idea Exchange to assess which features the community would like to see implemented. We greatly appreciate your contribution and will keep the status of this idea updated as we get new information on its potential implementation.
Gotyou
Onlooker
Agreed, other systems have this. Sometimes the trigger to record can be quite late (especially Arlo Go which has limited trigger range) so quite frustrating just to capture the last second or so before the object moves out of view!
Nepher
I don't think this is possible. Arlo cameras are OFF all the time to save battery, except for the PIR sensor which is a low battery consumption component. When PIR detects movement, it starts the camera. So, it is technically impossible to get 10 secs before the movement detection as the camera was off.
The only way to do that is to have it hooked to the power supplier... this way it works like a charm for me.
jetjockey21
Fledgling
Could a function like this be made available if the camera is continuously powered? There are a number of solutions now available to allow constant power to these cameras.
