Push Notifications - Select Guest Account Option Needed
With email notification you have the option of defining WHICH email addresses you want to receive notifications (per mode).
However, push notifications are either enabled / disabled, and go to the account owner and ALL possible guest accounts.  This is not ideal.
I would like to see a software update that allows you to select WHICH guest accounts will receive push notifications much like is done with email.
When you select the checkbox "Push Notifications", additional check boxes below it with "Acct Owner" and each possible Guest Account are listed for you to select / deselect.
Comments
TheWraith
Seems my text was cut off of the post (sigh).... add that to the list of issues with Arlo.
