- Community Home Home
- Community Browser:
- English
- Arlo Forum Discussions
- Arlo Idea Exchange
- Plastic Mount for Security
- Mark as Read
- Email to a Friend
I would like Arlo to make several plastic mounts for outdoor use that could make it more difficult to steal.
Here is an example of a (ugly but works well) mount I made using a plastic electrical junction box. It can mount with 4 to 6 long screws making it not worth a burglar's time to try to remove it, I used cheap window shims glued together, painted and screwed into the eave of my house. I only paid about $2 for the box although it was quite a bit of work to make as the inside of the box has many ridges that must be filed down. Since I drillled the holes in the eave slightly smaller than the screws, it takes quite a bit of work to remove it. Coupled with the solar panel it works out great even if it is ugly. I thiink a nicer looking mount could be made very inexpensively and sure would offer a great deal more security. I will try to insert some photos of my moount.
Front view
Top View
Side View
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Arlo Baby
73 -
Arlo Audio Doorbell
22 -
Arlo Security Light
