- Community Home Home
- Community Browser:
- English
- Arlo Forum Discussions
- Arlo Idea Exchange
- Outdoor Arlo Mount
- Mark as Read
- Email to a Friend
Outdoor Arlo Mount
Create a more secure mount or kit. Ive look everywhere and no one makes one. Maybe mfg a lock insert similarly found on laptops and sell an optional cable locking kit made from 1/16 aircraft grade cable and design it to where it can be attached to the outdoor mount via a hole made into the body of the mount itself which is hollow. Finally suggest security screws for mounting the mounting bracket itself. Yes if designed well, people will pay for it. I know I would have if it was available. For now I designed a semi-secure modification. A would be thief would need special cutter to cut through the aircraft grade cable. I used blue loctite on the wing nut to ensure it cannot be removed by hand. The loops were sized to keep them from being removed from the mount. I figure something is better than nothing.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Arlo Baby
78 -
Arlo Video Doorbell
34 -
Arlo Audio Doorbell
33 -
Arlo Security Light
Arlo Pro 3 Floodlight
15 -
Arlo Ultra 2
Arlo Pro 4
Arlo Essential Spotlight
Arlo Essential
Arlo Essential XL
