Idea Options
- Mark as Read
NAS storage and timeline search
Status:
Future Consideration
Submitted by
Srchangoor
on
2018-12-28
08:05 PM
I have been using Arlo for the past 7 months. While the hardware is great the operation is very basic for the price. The below are concerns that should be addressed.
1. NAS storage
While cloud storage is good for most people at this price point I would like the option to record locally to my nas and not be restricted by the need for an internet connection all the time.
2. Timeline search
To be frank your method of searching is terrible. It's the worst I have seen as an IT pro. Instead of image blocks, why can't you use a time line showing a grey bar with green bars showing motion recording. This makes it easier for the user to search and scroll through recordings.
3. I use Exacq for my business and the motion detection works excellent. The Arlo's on the other hand misses a lot of data which at times could be vital to an investigation.
4. Customizable views. Arlo allows for only one view to be reviewed at a time. There should be an option to view any cameras at once. Example let's say I have 8 cameras with 4 being outside and I want to view/review the 2 in the front and 2 at the back during a party I would have to constantly switch, unlink Exacq where I would just need to select the 4 camera I want to view
Thanks,
SC
1. NAS storage
2. Timeline search
Thanks,
SC
See more ideas labeled with:
Comments
- 2
- 3
- 4
- 2
- 3
- 4
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
