Idea Options
- Mark as Read
More Control Over Recordings: Fast Forward, Frame by Frame
I know this is primarily a residential system, but we use Arlo in our small business and sometimes I have to search through hours of clips to find the right moment. It would make it extremely beneficial to be able to set a play speed (2x, 4x, 8x) to be able to quickly scan through recordings, then go frame by frame to capture the exact moment I want.
Being able to capture a still frame is great and adding some editing afterwards would be nice, too. Timestamps and some basic highlighting/2D drawings all would be a fairly easy addition and helpful in the right circumstance.
See more ideas labeled with:
Comments
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
