- Mark as Read
Minimize lag by saving to USB drive first
I know I've seen a lot of complaints about lag. From what I see most of the lag is caused by the camera waiting for the network to be able to upload to the cloud. The mechanical part of the sensor being tripped and the lens opening is a second or less but if there is any network congestion or hiccup of any kind you camera can't record to the cloud.
Make it so I can buy a USB drive put it in the back of the base when a camera activates it records directly to the flash drive, once the recording is complete then it uploads to the cloud, but the actual recording is immediate, no waiting for the Internet. This simple solution would change how fast our cameras record
- 2
- 3
- 2
- 3
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
