Idea Options
- Mark as Read
Manual Deletion of Recycle Bin
Status:
Implemented
Submitted by
cyberjunkyfreak
on
2015-05-27
06:14 AM
Please allow us this option.
If the concern is that you want to protect a user's recordings, where an unauthorized user is looing to permanently delete "evidence", then perhaps you could incorportate a two-step verification to empty the recycle bin. For example, use Google Authenticator on a user's mobile device that prompts for a code every time a user attempts to empty the recycle bin.
Thanks in advance for the consideration.
Comments
- 2
- 3
- 2
- 3
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
