Making the mount movable
As we all know the Arlo wall dome has a great magnetic strength to hold the Cameras on the walls outside in place,but having most cameras high up firstly to gain better coverage and also to stop would be thieves from stealing our cameras ,what i think we all need is a way to have a outside wall dome that can actually  move the Arlo cameras into different positions saving having to go up a ladder, and use the position mode on the app on our smartphones to just move the cameras about maybe having a larger dome with a rechargable battery inside to do this function would be brilliant .
Comments
The Arlo development team routinely reviews posts in the Arlo Idea Exchange to assess which features the community would like to see implemented. We greatly appreciate the communities contribution and will keep the status of this idea updated as we get new information on it's potential implementation. Thank you for posting your idea!
Thank you,
greglee20
Thanks James .
Knightnj
Novice
It would be great if there was a mou t that allows you to remotely reposition your cameras.
They are all ready sold...do a web search. It's just that they are costly and prob a limited market here
Also there are other ip cams that tilt and pan.
As @TomMac  says, you can already buy such mounts that will work with Arlo cameras, just not from Arlo.
FWIW, I've found that the 180 degree field of view in the Ultra eliminates the need for this.
