- Community Home Home
- Community Browser:
- English
- Arlo Forum Discussions
- Arlo Idea Exchange
- Inactivity Duration Setting - Change from 10s of i...
- Mark as Read
Inactivity Duration Setting - Change from 10s of inactivity to stop a video to 15s or more
This has got to be the best feature request with the lowest amount of development time required. It's a no-brainer. Hear me out.
Arlo stops recording motion activated videos after 10s of inactivity. Almost every capture I get is cut IN HALF because the person/thing in motion stops for 10 seconds.
Example 1: My dog runs outside to use the bathroom. Arlo picks up the motion, starts recording, but after the dog is standing there peeing for 10 seconds, the video stops recording and I completely miss the dog running back inside.
Example 2: Garage cam. Arlo picks up me walking into my car. It takes 10 seconds for me to close the door, put my seatbelt on, switch into reverse, and start pulling out of the garage. Arlo stops seeing motion for 10 seconds and stops recording and completely misses me pulling out and closing the garage door.
Example 3: Someone walks up to my front door. They stand at the door searching their keys for my house key, and aren't moving for 10s. The video stops recording and completely misses the person entering the house.
These are just a few simple examples of how ~90% of my captures turn out. I'm always missing the latter half of the video. 10 seconds of inactivity is simply not enough. I would like a very simple setting to change the duration for inactivity in order for a video to stop recording from 10 seconds, to 15-20 seconds. This is different from setting a static amount of time for recordings. I don't want the same duration of videos every time, I still want inactivity to cause the recording to stop, but I want it to be a longer duration of inactivity.
Isn't that so simple? This simple feature would literally double the amount of action that is captured for my scenarios.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Arlo Baby
78 -
Arlo Video Doorbell
34 -
Arlo Audio Doorbell
33 -
Arlo Security Light
Arlo Pro 3 Floodlight
15 -
Arlo Ultra 2
Arlo Pro 4
Arlo Essential Spotlight
Arlo Essential
Arlo Essential XL
