- Community Home Home
- Community Browser:
- English
- Arlo Forum Discussions
- Arlo Idea Exchange
- Implement a lan ping instead of geofence
- Mark as Read
Hello,
first of all I apologize for my English but it's not my mother tongue, I write here because I think there'll be more audience.
Next, my idea is simple but I think it's very more reliable than state of art geofencing.
Instead of geofencing I'd to use a protocol of this type: the arlo base will periodiocally (one a minute) ping (a simply icmp ping or a tcp connection) lan IPs of the mobile devices with arlo app installed and authenticated, if all devices doesn't answer then the base will arm otherwise it'll disarm.
It's quite simple to implement and it's very reliable, as soon as a device will connect to wifi lan the arlo base will disarm, without the necessity to use gps, geofencing and other unreliable features.
There are some point to resolve (what lan IP are to be checked?) but they can be solved easily inside the arlo app (for example, once a device connects to wifi the arlo app will announce it's presence with a broadcast message or discover the arlo base and communicate it the lan IP to be monitored).
By the way, I underline the necessity to have an open Arlo API to bypass some missing features and to improve our smart homes.
Thanks in advance,
imopen
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Arlo Baby
78 -
Arlo Video Doorbell
34 -
Arlo Audio Doorbell
33 -
Arlo Security Light
Arlo Pro 3 Floodlight
15 -
Arlo Ultra 2
Arlo Pro 4
Arlo Essential Spotlight
Arlo Essential
Arlo Essential XL
