Room temperature light display
The temperature sensor is handy, but not very visible. There isn't the ability to have this remain on the app screen in a prominent postion, rather you have to click on the environment status icon to see it. We have a newborn, so the room temperature is something we are constantly monitoring as we're told this is a contributing to factor for SIDS. It would be very helpful to:
1) Have the temperature in a prominent position on the app screen at all times, perhaps next to the sensor/wi-fi/battery status icons in the navigation bar for quick reference.
2) Be able to set the light on the monitor itself to align with the temperature ranges specified in the app i.e.: light comes on red (or user specified colour) when over desired temperate range, comes on blue (or user specified colour) when below desired temperature range etc. Similair to the Gro-Egg concept: http://www.gro-store.com/gro-egg.html.
We like the night light feature but tend to set this to go go off after 30min at bedtime. So this would be a good multi-functional use for the light - and great safety feature for us parents.
