- Community Home Home
- Community Browser:
- English
- Arlo Forum Discussions
- Arlo Idea Exchange
- External Sensors w/o Cameras (External Motion Dete...
- Mark as Read
							External Sensors w/o Cameras (External Motion Detection/"Tripwire")
Because of Arlo's excellent video quality and excellent field of view I am able to see most of a large room/outdoor area with one camera. Unfortunately this tends to minimize the effectiveness of the motion detection as the camera tends to be more centrally located and so it does not detect something/someone until it is halfway or more across the room/area if it detects it at all. This leaves users with the undesirable options of either compromising their camera placement to accomodate motion detection or using an entire camera exclusively as a motion detector with little to no useful function as a camera. This latter scenario is a situation for which the camera is over-qualified and overpriced. A separate motion sensor that would trigger the camera to start recording when someone enters the room/access point would alleviate this issue. It could also help with the issue that myself and others are having with lag in recording start time. The sensor could be placed further out from the camera when necessary so that it could trigger the camera to start recording earlier, accounting for the lag time and recording what users actually wanted recorded.
An additional sensor would not be something that would be required of all cameras and placements, but it would be useful for specific scenarios and even having two sensors at opposite inds of a room/area triggering one camera could be a useful setup. As it is though, it is relatively cost prohibitive to expand your system to do this as the cameras are the only sensor option and cost too much to be wasted on being merely a sensor. Additinally these "wasted" cameras eat into your allotment under the current subscription you have and could create additional cost to the user for an upgraded subscription. As it is, I am hesitant to expand my system (currently at 4 cameras), even though I would like to have greater coverage, because of the up front cost of the cameras not being used to their full potential combined with the monthly cost of the upgraded subscription. I would be far more willing to expand my system and upgrade my subscription if there were external sensors that would allow me to use my system effeciently and effectively like I want to without the inflated up front cost.
I could see how this could be achieved either through hardware development of sensors exclusively for Arlo or through software development of integration with already established systems which perform comlementary functions. With either one, if the price is right I'm in, if it stays as it is my expansion is stuck.
- 9
- 10
- 11
- 16
- 9
- 10
- 11
- 16
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
						Arlo Web and Mobile Apps321
						Arlo Pro320
						Arlo Wire-Free197
						Accessories108
						Partner Integrations103
						Arlo Go78
						Arlo Baby78
						Arlo Q (Plus)72
						Arlo Ultra72
						Arlo Pro 266
						Arlo Video Doorbell34
						Arlo Audio Doorbell33
						Arlo Pro 332
						Arlo Smart31
						Arlo Security Light18
						Arlo Pro 3 Floodlight15
						Arlo Ultra 29
						Arlo Pro 47
						Features7
						Arlo Essential Spotlight4
						Arlo Mobile App3
						Google Assistant1
						IFTTT1
						Arlo Essential1
						Arlo Essential XL1
