- Mark as Read
Dynamic Continuous Recording on Motion
There is already a request for continuous recording but this is a little different.
Have a Checkbox for Dynamic Continuous Recording
You set your Camera to record on motion for 10 seconds and If with only 4 seconds left on recording and motion is still active, add another 10 seconds, and keep adding 10 if the motion threshold of 4 seconds left has been met or what threshold you set it at.
If no motion, stop at 10.
Most hits usually is a person or an animal or something passing by and usually out of frame within 3 to 5 seconds.
So now I can set my cameras for 10 seconds and if it is something passing through, my camera only records for 10 seconds and my battery life now has been extended. If there is movement, with my threshold setting set, recordings will keep going and I will capture everything without the need for the cameras to reset and miss something.
- 2
- 2
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
