Idea Options
- Mark as Read
Door sensor option
Status:
Future Consideration
Submitted by
acorreia
on
2015-06-09
06:56 AM
Instead of motion detection, can a camera be synced to turn on when a door opens? Example: I'd like to install in backyard where fence door is located, but a range of things would set the camera off in motion detect mode alone (leaves, a squirrel, kids playing, etc... ) so, it would make sense if it could start recording only if the backyard door were to be opened. An old camera system I had was synced to a z-wave door sensor and it would start to record only when the sensor activated which was perfect. Arlo support, any ideas?
Comments
- 2
- 2
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
