Idea Options
- Mark as Read
Disable cameras temporarily
I've seen this suggested several times over the past several years and I believe this would be a pretty simple addition to the apps. There are times I will disable certain cameras when I know people are going to be setting them off repeatedly. However, when I disable a camera I have to remember to turn it back on. Why not have a setting to temporarily disable one or several cameras for a finite period of time? Such a simple addition this would be to increase the usefulness of the cameras. Does anyone from Arlo read these suggestions?
See more ideas labeled with:
Comments
- 2
- 2
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
