- Community Home Home
- Community Browser:
- English
- Arlo Forum Discussions
- Arlo Idea Exchange
- Better Calendar UX
Idea Options
- Mark as Read
Better Calendar UX
The Arlo Calendar Needs a UX Overhaul
Many JavaScript libraries exist for calendars these days which are easy to implement and highly maintainable / portable. I am wondering why Netgear has chosen to roll it's own at least in regards to the user experience portion. Here are the main and obvious pain points:
- You cannot schedule overnight easily - why can't I start my watch at 11pm and end it at 7am? The validation here is goofy - remove it and be smarter by assuming the user means the next day then verifying they want next day..
- When I click on the calendar and the day/time modal opens, I see "[GREEN DOT] Armed" at the top. When I click on it, the entire line is highlighted green and a white check replaces the green dot. My question is: doesn't the presence of a green dot, as shown in the MODE view, indicate that Arlo is armed? Adding a check is inconsistent and confusing. Simplify and standardize.
- Non-standard time input fields - what is 01 AM ? Just roll the values up into a single select field.
- No click and drag to select times? This is probably because you rolled your own calendar. Users hate hard to use calendars and will probably refrain from using them if you make it difficult. The calendar could be an excellent feature with this functionality.
- You are using a limited styleguide or you are limiting use - for instance: why aren't DELETE buttons red with white text? This is pretty standard - why gray?
- DON'T disable buttons please. Users hate when buttons are disabled. Use better contextual messaging and strive to never disable buttons. This is a thing of the past and frustrates users.
In summary: consult a UX professional and don't rely on engineers to design your user experience! If you are very lucky, you might find someone who can harness both skills.
Comments
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Idea Statuses
Arlo Baby
78 -
Arlo Video Doorbell
34 -
Arlo Audio Doorbell
33 -
Arlo Security Light
Arlo Pro 3 Floodlight
15 -
Arlo Ultra 2
Arlo Pro 4
Arlo Essential Spotlight
Arlo Essential
Arlo Essential XL
