Idea Options
- Mark as Read
Base to automatically restart when there is no internet connection
Status:
Archived - Not Enough Votes
Submitted by
issacarya
on
2015-07-14
06:09 AM
I had a small problem the other day, my internet was working fine and wire was connected to my Arlo Base but Base wasn't detecting my internet.
I had to restart the Base manually. Imagine if you are on holiday and you are relying on this system.
What if Arlo Base can restart it self when there is no internet connection / Basically if there is a yellow light AUTO RESTART.
Usually when I restart the Base the problem is fixed, so why not the Base do it byitself.
AUTO RESTART IN THE EVENT OF A PROBLEM OR NO CONNECTIVITY / TIME OUT
Comments
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
