Idea Options
- Mark as Read
Allow multiple concurrent logins
Status:
Future Consideration
Submitted by
rerick
on
2015-01-11
08:16 PM
You need to allow more than one device to be logged in at a time. In a family situation, my wife and I both need to have access to the cameras and push notifications without kicking eachother off. Allowing only one at a time really makes no sense for a product that is aimed at household security. I have a LOT of devices and I use several at once.
By the way, this is not the same thing as the "friend" feature which allows you to share cameras with other people (if you pay for a better plan).
Comments
- 8
- 9
- 10
- 11
- 12
- 8
- 9
- 10
- 11
- 12
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
