3/4 sphere mounts, not hemisphere mounts
I suggest that the provided mounts be 3/4 spheres, not hemispheres.
The hemisphere mounts limit the range of adjustment just enough to be annoying.  i realize that it's easy to manufacture the hemispheres with the metal press technique, but 3/4 spheres would provide a much better product.
Comments
You might take a look at the Arlo Table and Ceiling mount as it may fit your needs as described: Table and Ceiling Mount (VMA1100)
_nd345
I saw those, but are pricey.  I basically want what they provide with more range (3/4 sphere would do this perfectly).  It would be much better.
This would work too: (You are welcome, Netgear can give me some royalties!)
