- Community Home Home
- Community Browser:
- English
- Arlo Forum Discussions
- Arlo Idea Exchange
- "Arlo NFC switch": a physical switch + NFC tag at ...
- Mark as Read
"Arlo NFC switch": a physical switch + NFC tag at your front door
TL;DR: Use a physical button / NFC tag at front door to turn ON / OFF the cameras.
Geofencing mode is nice but it's very difficult to make it work properly.
If you base the geofencing on the phone's location, you need to have the location service always running on your phone, which drain the battery.
Also, most people don't live alone, so you need to have the same service running on several devices.
If you base the geofencing on the phone's presence on the home network, it's not going to work properly as, unless set otherwise, the phone will
turn off its radio regularly to save power. If you change the settings on all the phones, it will drain their battery faster.
A simple way to tackle this would be to use a little piece of hardware that could be used to easily turn on and off the cameras.
This little box could be wirelessly attached to the Arlo station and physically attached near the front door. It should support NFC and have a physial
button to turn the cameras on.
- When you leave the house and want to turn on the cameras, simply press the ON button before leaving. A notification is pushed to the phone to
confirm that cameras were activated. That way, you don't have to launch the app, connect to your account and change mode. If for some reason, the
activation with the button doesn't work with the physical button, even if you're already gone, you can still activate the cameras from the application.
- When you come into your house and want to turn off the cameras, an OFF button is not enough, identity and authorization must be verified. That is
the purpose of the NFC tag. You could simply pass your phone in front of the "Arlo NFC switch". The phone would read the NFC tag in it, launch the
Arlo app, check authorization and show a simple button to turn the cameras OFF. That way, you don't have to manually launch the app, connect to
your account, change mode, etc.
Imho, this would be easier to set up, to use and more reliable than the software geofencing.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Arlo Baby
78 -
Arlo Video Doorbell
34 -
Arlo Audio Doorbell
33 -
Arlo Security Light
Arlo Pro 3 Floodlight
15 -
Arlo Ultra 2
Arlo Pro 4
Arlo Essential Spotlight
Arlo Essential
Arlo Essential XL
