- Community Home Home
- Community Browser:
- English
- Arlo Forum Discussions
- Arlo Idea Exchange
- Telephoto (long) lens - for greater reach
- Mark as Read
My contention: The 130° angle of view (aka field of view) of the Arlo Q is great for most situations. But there is occassionally a need to zoom in on a particular area, say a gate located at the end of a driveway. This calls for a longer (telephoto) lens.
Proposal: Design and sell a lens adapter which extends the reach of the lens, in the same way that there are lens adapters for smartphones which increase the effective focal length of the lens. Or better, have interchangable lenses.
Evaluation of my idea:
- A high-quality lens adapter could be expensive
- There may be little demand for a longer lens
- The lens adapter has to be very large in order to ensure a good effective f-stop number and thus maintain good low-light recording capabilities
- IR recording may no longer be possible, necessitating the use of security lights
- With a telephoto lens, the Arlo Q could be deployed in a sheltered area of the house which would previously have required an Arlo Wire Free to cover the same area.
Alas, my suggestion may, as usual, gain no viewship or support. Here's hoping that will change. If not, I shall not waste my time here. I'll let the community decide using the "Kudos" button.
- 2
- 2
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Arlo Baby
78 -
Arlo Video Doorbell
34 -
Arlo Audio Doorbell
33 -
Arlo Security Light
Arlo Pro 3 Floodlight
15 -
Arlo Ultra 2
Arlo Pro 4
Arlo Essential Spotlight
Arlo Essential
Arlo Essential XL
