Solar panels used as wireless extender for camera
Hi All,
It seems possible that for cameras using a solar panel there may be some distance to the camera.
It may be practical to include a wireless extender in the solar panel to increase camera connectivity for cameras some distance from the smart hub?  If more power is required to run the extender and charge the battery then increase the size of the solar panel?
This would connect on the Arlo Pro3 through the charging port area - probably most practical.
Comments
ShayneS
Hi @Nonia
We greatly appreciate the community’s contribution and will keep the status of this idea updated as we get new information on its potential implementation. Thank you for posting your idea!
