Solar Panel To Start Charging At Specified Percentage
Make a setting on the devices ,that can charge from the solar panel, a percentage level to start charging. Insead of charging when sunlight make it when sunlight and <= 25% for instance. Then the customer can set there level they want. Just like with cellphone to much charging can hurt the battery life.
Comments
ShayneS
We greatly appreciate the community’s contribution and will keep the status of this idea updated as we get new information on its potential implementation. Thank you for posting your idea!
fisheye7
Does the solar panel not cut out when the battery charge reaches 100% charge?
If it doesn’t cut out, could this cause damage and/or wear out the battery quicker?
ShayneS
Hi @fisheye7
  Have you tried contacting customer support regarding this question? I have attached the link here for you - Arlo Tech Support
fisheye7
Thank you for your comment. Hopefully the manufacturer of the Arlo Solar Panel would have thought of an overcharging situation & built in some sort of cut off which then would start to recharge again once the level dropped but who knows, perhaps we’ll get an informed answer from them here. There’s nothing in the manual that states this.
