Secure option of only being able to delete recordings and change settings when on same wifi network?
An option to only make changes to the mode and delete recordings when on the same wifi network would reduce the chance of the system being hacked and would narrow the list of those who might be responsible if it does take place.
This is happening and changing the password only temporarily secures the account. An unauthorised user has changed modes, apparently turned off cameras and recordings have failed to appear in the library.
Comments
Jalsteen
Only comment to this is you would need to test, test, and retest to make sure you have things set correctly.  if something happens such as a camera not arming or some other glitch, you would have no way to correct it till you came home.  if you are gone on vacation or whatever.  My thoughts are if someone wants to hack in and see an empty room, have fun I guess.
