Idea Options
- Mark as Read
Please create a secure mount which can be attached to a tree (trail mount)
I have a mailbox which keeps getting broken into.
Currently the camera is mounted up above the garage to keep it from getting stolen (hopefullyl) I would like to mount it on a tree closer to the mailbox - at eye level. But I can't because the current mount design makes it too easy for the camera to be stolen.
Please make a lockable secure trail mount for the Arlo. Something like this:
Ideally the box should have a hook so it can be locked with a build-in combination lock. If that is not feasible, you can make it so an external padlock can be used to lock it.
Thanks in advance!
See more ideas labeled with:
Comments
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
