Multi delete function
Set up where you can delete multiple recordings at one time or where you can delete all recordings except favorites.
having to go one at a time is very time comsuming.
Comments
ShayneS
Hi @TwoCrows
On the Arlo Mobile App, you can hold down on a video > select multiple recordings. On the Web Portal, you can go to Library > Select > Select Desired videos > Delete.
