Library Clip Filtering
I would like to filter on the duration of clip.  With a camera pointed out the window at the street and the unreliability of zone detection I have no choice but to detect motion on the entire field of view.  A car going by is a clip of 20 seconds but anything over 20 requires I take a close look.  If I could filter on clips > n seconds that would be great.
Comments
asoueid
Fledgling
The video clip library is typically filled with many short video clips that are not significant.  The filter feature is very limited.  It would be great if it provides the ability to filter view of the library based on duration range of video clips.  Have the ability to select a range in seconds or just check boxes to view videos in these categories:  0-20 Seconds, 20-40 Seconds, 30-60 Seconds; and Over 1 minute long.
