- Mark as Read
Have two motion sensitivity settings: One to trigger, one to continue recording
I want to be able to have a relatively high threshold before a motion triggers a recording, to reduce false positives. But once a recording starts, I want the sensitivity to be high so it continues to record when the subject is only moving a little bit.
For example, someone walking into view of the camera registers as a high motion event and triggers a recording. But then they stop somewhere (perhaps to look into my window?) and are not moving enough for the motion sensitivity to count it as motion. The recording stops while they're still in view of the camera, which is bad. I don't want the clip to stop just because they stopped walking. If they're still moving at all (head, arms, etc) then I want the clip to continue. The motion sensitivity needs to be higher during the recording - separate from the initial trigger sensitivity.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
