Feature Request: IFTTT / Stringify Temperature Integration For Arlo Baby
I can set actions in IFTTT or Stringify when motion is detected but would like temperature integration for the Arlo Baby Cam
e.g. As a user I would like my Nest Thermostat to turn on when Arlo Baby Cam detects that temperature drops lower than 17degrees in the nursery.
I can currently use IFTTT to send alerts when motion/audio detected or low battery reported but temperature/humidity/air quality isn’t connected up to IFTTT yet.
Comments
eeee
Fledgling
I can’t believe this is not supported! I thought it was already available and is partly why I bought this baby monitor. Please enable this for temperature, humidity, and air quality - it would be so useful!
MacComp
Novice
I've managed to use the temperature sensor as a trigger via the Eve App as well as the Home+ App on iOS to switch on and off a fan.
The thing is that it only reports the temperature to the trigger a couple of hours and then it stops working and the fan keeps turning although the temperature already dropped enough.
