Idea Options
- Mark as Read
Feature Request: IFTTT / Stringify Temperature Integration For Arlo Baby
I can set actions in IFTTT or Stringify when motion is detected but would like temperature integration for the Arlo Baby Cam
e.g. As a user I would like my Nest Thermostat to turn on when Arlo Baby Cam detects that temperature drops lower than 17degrees in the nursery.
I can currently use IFTTT to send alerts when motion/audio detected or low battery reported but temperature/humidity/air quality isn’t connected up to IFTTT yet.
See more ideas labeled with:
Comments
- 2
- 2
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
