Dual Brightness
Give us a dual-bright setting on the floodlight camera. The ability to set the light at a constant 20 percent (for example) and if motion is detected, it will automatically switch to 100 percent and stay that way for x amount of minutes.
Comments
lbal
I’d like to add onto this as it’s similar in nature to another idea that is posted. Let’s say you are using the outdoor magnetic power cable (or not even), a nice update I’d like to see is for some options for it to act like a regular floodlight. For example, have a setting where the flood light stays on from dusk to dawn, turns on at dusk and stays on for say 3 or 6 hours. Besides being able to change how long it stays on, in parallel modifying the Lumens so that the light can maybe operate at a lower value to act as an accent light all the way up to full brightest if one desires.  Things like this would be a great addition I believe.  Hope others here agree.
