Idea Options
- Mark as Read
Defining motion sensitivity at the zone level
If it is not already possible, would you be able to add the ability (through a firmware update) to define the motion sensitivity at the zone level?
Say I specify 2 zones: one for close up, and one for the background.
Then I want to set a different sensitivity for each of the 2 zones.
Thank you!
See more ideas labeled with:
Comments
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
