Idea Options
- Mark as Read
Custom alert sounds for Android/iOS
Status:
Partially Implemented
Submitted by
Alpo
on
2015-01-27
07:56 PM
Really need to customize the notification sound. For instance, I want to be alerted to motion on some cameras while sleeping, but the notification sound is not enough to do that because it is too brief and I just sleep right through it. Would be nice to select an mp3, or at least provide some more aggressive options for alerts. Perhaps even per camera custom sounds, as one can do with ringtones for different contacts.
See more ideas labeled with:
Comments
- 69
- 70
- 71
- 69
- 70
- 71
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
