Idea Options
- Mark as Read
Connecting Orbi to Arlo
It's time you add support between your Orbi and Arlo product lines.
I have an Arlo VMC3030 (video) and an Orbi AC3000 (wifi). It would have been great if e.g.
- The VMC3030 could expand the range of the Orbi system in order to get even better WiFi coverage.
- The Orbi system could be used to extend the range of the Arlo cameras, enabling greater distance between the cameras
- Enable distribution of Arlo camera contents in the local network (use the Arlo cameras as WiFi Web-Cams), so that anyone on the local network could see the latest video or the latest screenshot from the cameras
Comments
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
