- Community Home Home
- Community Browser:
- English
- Arlo Forum Discussions
- Arlo Idea Exchange
- Automatically transfer/backup/copy Arlo videos to ...
- Mark as Read
Automatically transfer/backup/copy Arlo videos to Google GDrive cloud and autodownload to PC - Part1
After failing to find a decent solution on Arlo forums, and Netgrear having no native solution for this, I figured out how to do this with Stringify. However if you haven't used Stringify before, the setup can be a little daunting. Hopefully these instructions will help someone.
Install Stringify on your iOS or Android device from your relevant app store.
Once installed and logged in, choose the Home icon to make sure we are all starting from the same place.
Now press the PLUS "+" icon and choose "Add a New Thing".
Scroll down the alphabetical (but non-searchable) list. Find and choose - Netgear Arlo Cameras
When the Netgear Arlo Cameras thing is showing, choose "Flow Ideas"
... then "Unlimted Video Recordings"
The "Recipe" for this flow is WHEN New video on my Arlo is recorded THEN Upload a file to my Google Drive
Click "Get Flow"
follow the phone's onscreen instructions.
- Click the Arlo "thing" - you will be prompted for your Arlo credentials so Stringify can login on your behalf.
- click the X in the upper left corner to leave this tab and go back to the Stringify canvas.
- this will have added each of your cameras and your base station as new Things in your Thing menu.
- Click the Google Drive "thing" - you will be prompted for your Google Drive credentials so Stringify can login on your behalf and copy the Arlo video over
Now press on X in the upper right corner. This modified Flow has been saved.
You may end up back at the Stringify app home page. If so, click on Flows in the bottom menu and find your Flow. It's not fully configured yet because you need to configure it for the videos for a specific camera, and then you will duplicate the flow and choose other cameras if you have them.
So, edit the Flow you just made, click on the Arlo thing, and choose the Camera you want to have the videos transferred for.
You might also want to rename this flow to something more meaningful like "Arlo Porch to GDrive"
If you have successfully configured your Arlo thing (i.e. chosen the camera) and also the GDrive thing (it has your login credentials) then at the bottom of the Flow canvas screen it should say "Enable Flow". Click it.
You should get a "Success" message. You can now click the X in the upper right and go back to your list of Flows.
Continued next post ...
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Arlo Baby
78 -
Arlo Video Doorbell
34 -
Arlo Audio Doorbell
33 -
Arlo Security Light
Arlo Pro 3 Floodlight
15 -
Arlo Ultra 2
Arlo Pro 4
Arlo Essential Spotlight
Arlo Essential
Arlo Essential XL
