Idea Options
- Mark as Read
Arlo Geofencing - Force Location Update
Hi, I would like to suggest do add a button to re-check your actual location. Sometimes even if you are at home it keeps telling that you are away and alerting every motion. Turning GPS, wifi, mobile data off, doesn't work. The only way is to disable geofencing then enable it again. Too much work. Hope this can be improved.
See more ideas labeled with:
Comments
- 2
- 3
- 2
- 3
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
