Idea Options
- Mark as Read
Arlo Audio Doorbell Integration with Google Assistant
Hi, are there plans to add integration between the Arlo Doorbell and Google Assistant? Specifically it would be great if it's possible to have the Google Home and Home Hub make an announcement when the doorbell is pressed. Ideally the Home Hub should bring up the attached camera as well. Thanks.
See more ideas labeled with:
Comments
- 2
- 2
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
