Idea Options
- Mark as Read
Allow us to monitor single camera history
Status:
Implemented
Submitted by
o-cloughie
on
2018-10-30
12:51 PM
I have spoken to Arlos CEO about this who agrees this is an oversight for multiple users. Monitoring - Before the firmware change I could simply pick a camera click on the (0) and look at data for the last 60 days on that camera. Now because the (0) has been removed, (available on a PC only) I cannot do this. I had two incidents the other day; a man called at my main gate and I was away but once I’d checked the main gate camera then switched to another I couldn't go back into the main gate camera archive to see if he had been past my property earlier that day or any of the previous days. I had to go to the Library app which contains the hits of 32 cameras all mixed which was pretty much unusable and took far too long. now I have since been made a way of a short cut via the Library and filter button but this is an extra 3 clicks and is time consuming when time in securitybis if the essence when you have intruders or need to look at history. In addition the filter library includes old cameras no longer used on the system which is confusing. Please can you put the (0) back that gives us immediate access to any dedicated camera and their archive. This is your biggest selling feature so I can’t believe you deleted it. Thanks
See more ideas labeled with:
Comments
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
