- Community Home Home
- Community Browser:
- English
- Arlo Forum Discussions
- Arlo Idea Exchange
- Add support for USB WIFI Dongle to the Arlo Pro B...
Idea Options
- Mark as Read
Add support for USB WIFI Dongle to the Arlo Pro Base Station
Would be great if the Arlo Pro Base Station was able to support a USB WiFi dongle so you could connect it to your WiFI Network rather than using Ethernet.
With the addition of the Siren feature being able to place the Base Station without the requirement of running an Ethernet cable to it would be extremely valuable.
Most dongles use generic settings/config so it should be pretty easy to incorporate a set-up menu into the Firmware/Software or even if Netgear produced a specific dongle to for use with it.
Comments
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Idea Statuses
Arlo Baby
78 -
Arlo Video Doorbell
34 -
Arlo Audio Doorbell
33 -
Arlo Security Light
Arlo Pro 3 Floodlight
15 -
Arlo Ultra 2
Arlo Pro 4
Arlo Essential Spotlight
Arlo Essential
Arlo Essential XL
