A security light on/off
There doesn’t seem to be any outdoor security light that can be permenently turned on using the cloud. If you are out you might want to turn a back light on permanently or on a timer. Your lights just come in with movement but having this option is good too! Due to battery life it would probably be be best hard wired
Comments
ShayneS
o-cloughie,
If you would like to turn the Arlo Securtiy Light to a Always On state, you may go to Devices > Arlo Security Light > Edit Tab > Duration > Always On OR Set A Duration. The Arlo Security Light battery life for the Arlo Security life expectancy is similar to an Arlo Pro under normal usage. If you were to manually activate the light and leave it on continuously, it would last for over 6 hours at max brightness on a fully charged battery.
