Idea Options
- Mark as Read
"Delete" or "Continue" buttons are swapped compared to iOS and PC?
This is just a small suggestion. I noticed when using IOS App and the PC web browser interface when deleting items from the Library (something that I do quite often) the confirmation on the delete button is on the right in the PC (browser) and the button is labeled "Delete" and in the IOS app the confirmation button is on the left and is labeled "Continue". Why are these button not on the same side and why are they not both labeled either "Delete" or "Continue"? It would be nice if these were consistance across on both apps.
See more ideas labeled with:
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
